Results 1 to 22 of 22
  1. #1
    Default A Lot of Play in Gear Shift Handle
    Hey folks, I just picked this motor up. It doesn't pump water so I'm getting a new impeller, but there's another thing I noticed that I don't know how to fix. It will shift through all the gears just fine, but once in any of the gears (F, N, R) there is a lot of play in the handle. I'll link a video. What does it take to fix this?
    Thanks for all the help!
    https://vimeo.com/463999127
    Edit: 6hp Evinrude, think it's around 1975, the model/serial number plate seems to have been removed for painting and never found its way back on.
  2. #2
    Join Date
    Sep 2010
    Posts
    21,184
    Default Re: A Lot of Play in Gear Shift Handle
    Check the bolts in the shift rod connecter.----Or the bell crank at the top of the shift rod is broken.----Remove lower unit for the first item.----If that is good then check shift rod going into the lower unit for any slack.-----Powerhead needs to be removed to inspect top of shift rod..
  3. #3
    Ok, thanks racer.
  4. #4
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    4,085
    That's busted up top..... I'm pretty sure. Got one at home.....same thing. We are up on Canada border....little fishing, camping break. Had to check in so my friends here won't think I died. The one I have at home will be repaired upon our return. Already have it sold. Wish I had it here instead of this worthless 4 stroke Yamaha 4 horse......looses spark when hot.
  5. #5
    Busted up top meaning I'll have to pull the power head and have a look?
  6. #6
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    4,085
    You can split the water pump opening just enough to see shift shaft to make certain. Then move forward if you see movement not corresponding to shift lever action.....then you will know for sure where the slack is. Then remove powerhead and repair, my friend.
  7. #7
    Join Date
    May 2015
    Posts
    2,452
    Maybe it will fix itself if you put some amsoil on it.
  8. #8
    Join Date
    Nov 2011
    Posts
    3,149
    In the original post, you said you are going to replace the water pump anyway. Seems pretty cut and dried to me. Go ahead with the water pump job. As part of the job, you will have the lower unit off. Then there is no better or surer way to diagnose the shift looseness. Simply grab hold of the shift rod and see if it slops up and down. Instant diagnosis.
    My bet is the powerhead has to come off. No big deal, easy job.
  9. #9
    Thanks everyone for the feedback. I'll give an update once I get the lower unit off, won't be for a few days, don't want to upset Boobie if he's watching.
  10. #10
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    4,085
    Ha! Good idea.....for sure.
  11. #11
    Ugh, I just snapped the heads off of 2 of the 4 bolts holding the lower unit on. Will I be able to pull the lower unit off through those bolts or is the bottom part threaded along with the top part?
    Edit: If it matters the two that snapped were on the back side, the two on the front came out intact.
  12. #12
    Join Date
    Nov 2011
    Posts
    3,149
    It should pull off those broken bolt remains. However, they probably are seized/corroded in the aluminum surrounding them. That is why they wouldn't turn, causing them to break
  13. #13
    So I'm thinking some heat, some wiggling, some wooden hammer tapping, and a lot of patience is the trick.
  14. #14
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    4,085
    Might need a little heat and tapping. Salt water motor?
    Gonna fix my 6 hp tomorrow morning with same sloppy shifter.
  15. #15
    I didn't think it was a salt water motor, but I didn't ask when I picked it up.
  16. #16
    I didn't know if I should make a new thread or reuse the old post. I finally got around to getting the lower unit free. I noticed that the gear shift linkage screw heads were on the port side of the motor. The manual shows the heads on the starboard side of the motor. I'm suspicious that the previous owner flipped it around. Can you men of great experience tell me if this is correct?
ID:	25947Click image for larger version.
  17. #17
    Join Date
    Sep 2010
    Posts
    21,184
    It makes no difference which way it is.
  18. #18
    Ok, thanks. I'll get a water pump repair kit and put it back together to see if the play was in the linkage or not.
  19. #19
    Join Date
    Sep 2010
    Posts
    21,184
    I would pull the power head ( easy ) to inspect linkages.-----And the important mechanical seal under the power head.
  20. #20
    Join Date
    Apr 2010
    Posts
    5,036
    What are you going to upset Boobie about ????
  21. #21
    Quote Originally Posted by Boobie View Post
    I have noticed that you don't like it when people take a long time to act on the advice of the people on the forum, but I knew it was going to take me a long time to work on this motor.
    As for pulling the power head. The screws holding the power head aren't any kinder than those that held the lower unit. I snapped one trying to get it off. I'm not looking forward to the potential headache of all of them breaking so I think I will wait for spring to continue work on it.
  22. #22
    Join Date
    Apr 2010
    Posts
    5,036
    Don't worry Swarlos, I'll try to avoid ever helping you again. It's just common courtesy to get back to a person that has helped you on a problem but O'well.
Similar Threads
  1. Nissan NS5B gear shift handle question
    By jd11265 in forum Nissan Tohatsu Outboard Forum
    Last Post: 05-19-2018, 03:16 PM
  2. Yamaha Mariner 5HP gear shift handle
    By worldbfreebase in forum Mercury Mariner Outboard Forum
    Last Post: 04-16-2018, 12:14 PM
  3. 5 hp gear shift handle replacement
    By triton1999 in forum Mercury Mariner Outboard Forum
    Last Post: 06-14-2017, 12:56 PM
  4. Looking for a Gear Shift Handle for an older 5 HP Mariner HELP?
    By malcod99 in forum Mercury Mariner Outboard Forum
    Last Post: 07-06-2015, 07:28 PM
  5. Gear shift handle
    By jeffrey dee in forum Mercury Mariner Outboard Archive
    Last Post: 09-29-2007, 04:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
