What is L and R on the alternator?
Bigdrago
Hello. I have Mercruiser 1.7 DTI with alternator that have L and R terminals. L is for the charging light on dashboard. But what is R doing?
Does R output the same power as B+ ? Wire scheme is attached.
Being that your R terminal is fed from the ignition, its likely the "excite" function that gets things charging when you start the engine...
So, the R terminal is an INPUT, not an output....it is switched so the alternator shuts off with the engine.
