MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
    Sep 2019
    toronto
    19
    Default Need help. Why 20hp mariner 2 cylinder motor runs slow
    Hi all friend.
    This morning i tested the 2 cylinder and getting both 120psi. But on full speed but my speed is only 11 to 13km/hr.
    Any suggestion please
    May 2015
    2,360
    Default Re: Need help. Why 20hp mariner 2 cylinder motor runs slow
    Check for spark sounds like it is running on one cylinder.
    Sep 2019
    toronto
    19
    Quote Originally Posted by flyingscott View Post
    Can you or some one guide me how to check?
    May 2015
    2,360
    With the motor running pull one spark plug wire off at a time. Use a plastic pliers to pull the wires off. It should be able to idle on one cylinder at a time. Report back results.
    Sep 2019
    toronto
    19
    Ok when engine running i tried take the one plg out, sound was less but engine was keep running, turn off the engine, put the plug back in, atart the engine, now took the other plug out, same sound was less but engine was keep running, tested before both cylinder got 125psi.
    What could be the issue?
  6. #6
    Sep 2019
    toronto
    19
    Ok when engine running i tried take the one plug out, sound was less but engine was keep running, turn off the engine, put the plug back in, start the engine, now took the other plug out, same sound was less but engine was keep running, tested before both cylinder got 125psi.
  7. #7
    Sep 2019
    toronto
    19
    Hi all, just to update i clean the Carb, rebuild with original gaskit, bought from mercury, but progress doesnt change after few start engine doenst start, amd speed ia the same 11 to 13 km/hr, i dont know what else i have to do.
    Any suggestion.
  1. Mariner 20hp runs when it wants
    By panthers06232 in forum Mercury Mariner Outboard Forum
    Last Post: 09-15-2020, 07:14 PM
  2. How to check if speed is good on 20hp mariner outboard motor
    By Theshoaibahmed in forum Mercury Mariner Outboard Forum
    Last Post: 08-10-2020, 07:41 PM
  3. Slow starter motor Mariner V6 175 hp
    By Sarrre in forum Mercury Mariner Outboard Forum
    Last Post: 10-20-2015, 09:21 AM
  4. 2 cylinder Mariner 55 won't idle but runs like a train
    By wynjim55 in forum Mercury Mariner Outboard Forum
    Last Post: 06-13-2015, 02:30 PM
  5. 1987 Mariner 20HP #2 Cylinder Intermittent Fire
    By C4PZL0K in forum Mercury Mariner Outboard Forum
    Last Post: 01-20-2014, 06:49 AM
