[email protected]
First question: Is there an easy way to replace the two o rings in the housing top of the gear shifter shaft in the lower unit? It is trying to beat me!!!!
Second Question: I am going to change out the VRO fuel pump for a straight gas fuel pump. Any suggestions or tips? I would like to remove the oil storage tank, without destroying it, but the winged knobs just spin. They seem to be spring loaded but I can't figure out the removal sequence. HELP!!! Thank you.
Carter
Carter
