Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 5 of 5
    Jul 2019
    Willsboro, NY
    16
    Default 1976 Chrysler 35 hp coil issue
    My 1976 Chrysler 35 hp has the battery type ignition that uses two, 12 volt, externally mounted coils. One has cracks
    in the casing. It still produces a spark but runs very hot. Probably won't last much longer. These coils are very expensive
    to replace. Has anyone else had this problem and used a small, 12 volt automotive coil to solve it ? Thanks
    May 2010
    Sebastian ,Fl
    3,059
    Default Re: 1976 Chrysler 35 hp coil issue
    http://standardmagneto.com/index.html
    Try here for cheaper parts.
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
    88 Bayliner with 2002 225 HP Mercury
    Buy American made Cars and Trucks!!!Towing insurance,get it.
    In Scenic Beautiful Sebastian by the sea Florida
    Jul 2019
    Willsboro, NY
    16
    Thanks, I will check with them.
    I did discover that both coils run hot depending on what point set is closed at the time. I guess it makes sense because they each
    have 12 volts applied to their individual circuits whenever the ignition switch is on. The mounting bracket that holds the coils is very
    substantial and maybe it was designed to also act as a heat sink. Anyone have similar experience ?
    Thank you
    May 2010
    Sebastian ,Fl
    3,059
    Coils should run hot but not so hot
    that it would burn you.
    If they spark, just use them and see if they fail?
    You can always fill in the cracks with Liquid Electric
    Tape.
    Jul 2019
    Willsboro, NY
    16
    Thanks Jerry, I really appreciate your help.
  1. Coil Assembly Trigger for 1976 - Model 110 - 9.8 h.p.
    By J.J. Zimmerman in forum Mercury Mariner Outboard Forum
    Last Post: 04-19-2018, 01:37 AM
  2. 1976 chrysler 75 hp
    By JSC14JEAN in forum Chrysler Force Outboard Forum
    Last Post: 01-04-2016, 08:59 AM
  3. 1976 Chrysler 3 cyl, 75 hp
    Last Post: 07-26-2015, 07:47 PM
  4. Chrysler 1976, 75 hp 3 cyl.
    Last Post: 07-26-2015, 07:38 AM
  5. Chrysler 30 hp coil replacement
    By marfarkle in forum Chrysler Force Outboard Forum
    Last Post: 08-04-2014, 10:03 PM
