Results 1 to 5 of 5
  1. #1
    Default 40 HP Evinrude, 1990, Model VE40TLESR, battery charging system not working adequately
    I changed the voltage rectifier on this engine already, but I still only get about 12 VDC (measured across the battery leads) when running the motor at any RPM with the navigation lights on, which eventually drains the battery. I get up to 13 VDC with the lights off.
    What is the next thing to look at?
    Is it the stator assembly, and if so what voltage should I be getting out of it where it connects to the rectifier?
    I am told the stator produces an AC voltage.
  2. #2
    Default Re: 40 HP Evinrude, 1990, Model VE40TLESR, battery charging system not working adequately
    Quote Originally Posted by Ernie84 View Post
    Boat wiring.
    Ac volts is correct.
    This system only produces five amps at full throttle,
    Check boat wiring,condition of battery
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    15,845
    If your setup incorporates a tachometer... and the tachometer is functioning properly, the charging system is okay.
    And if the charging system is okay, then as RwButler insinuates, I'd suspect a failing battery.
    We occasionally have questions. If you fail to answer, it may affect ours.
  4. #4
    Join Date
    Nov 2011
    Posts
    3,030
    You only get out of a battery what you put in the battery. So how many amps are you pulling out of the battery? I haven't looked the model number up, but does it have power trim?
    Is your 12VDC an accurate measurement? That's low for a fully charged battery.
    Considered changing the light bulbs to LED?
  5. #5
    Thanks to all for your help.
Similar Threads
  1. Replies: 2
    Last Post: 08-26-2020, 02:15 PM
  2. 40 HP Evinrude, 1990, Model VE40TLESR, Acceptable Compression range
    By Ernie84 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-21-2020, 02:00 PM
  3. 40 HP Evinrude, 1990, Model VE40TLESR, Shift Rod grommet # 0321452
    Last Post: 08-21-2020, 12:55 PM
  4. 40 HP Evinrude, Model VE40TLESR, battery charging system not working
    Last Post: 08-12-2020, 06:00 PM
  5. How to test if your enginebs battery charging system is working or not
    By trippster in forum Mercury Mariner Outboard Archive
    Last Post: 07-10-2008, 04:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
