I realize there are other timing forum posts out there but none of them answer my question clearly so here goes. I have a 1989 Mercruiser 3.0L (0C528921) that I upgraded from the original breaker point system to the Delco Remy Voyager EST. Question I have is what does the new timing get set to? The specs on the flame arrestor cover indicates 6 degrees BTDC. Do I adjust back to the 6 degrees BTDC in base timing mode or normal idle (not in base timing mode) at 750 rpm. Or is there a new set point all together?
I have scoured the Internet for hours to no avail. Any help would be appreciated. Thanks!
