DPForumDog
Our TellTale water is about 160 degrees but when we put a heat gun on our engine the temp is 190-200 degrees. Is that normal? Should the Tell tale temperature be the same as the motor temp?
We drove the boat hard and fast for 10 minutes with approx 3800 to 4000 rpms and then came back and put a heat gun on the motor in several different places and got 190-200.
Last night Paw put in new impeller (pump). We will repeat test today.
Ill let you know.
Granny DP
Ill let you know.
Granny DP
