Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 4 of 4
    Post 1986 Tohatsu M70A2 power tilt/trim PLEASE HELP
    Hello all! I am a mechanic and recently had a buddy bring me his 1987 skeeter with an '86 Tohatsu 70hp that has power tilt/trim and cooling issues. I'm pretty sure the model is an M70A or M70A2. I've dealt with running issues and electrical portion of tilt/trim problems and drained old fluid from trim pump, added new and bled the system. I am not super familiar with the hydraulics in tilt trim systems however am very familiar with machinery hydraulics and how they work. At this point I am certain that the remaining problem lies in the hydraulic circuit. The electric motor functions in both directions(up and down) and sounds like it is healthy but it sounds as though it has 0 resistance in the circuit. I am familiar with how it should sound under load and it is way to high pitched as the motor is clearly spinning at max rpm with 0 resistance. After opening up the pump housing and taking a closer look I noticed that with the manual release valve closed and seated tightly the port to the reservoir portion was not closed off. This would seem to clearly explain why it is not working and why it sounds like the motor is spinning with no resistance in my mind. After removing and looking a bit closer at the release valve it seems to me there may be some parts missing. I told the owner my concerns and he informed me that he had halfhazardly removed the valve prior to bringing it to me at which time he realized that is the exact moment the trim stopped working! At this point I believe there is a shuttle valve missing like several other manumanufacturers manual releases make use of. My problem is I don't know what all is missing if anything and if I can make the parts, since I have discovered finding parts for this unit is next to impossible, how they go back together! Also when we opened the pump housing and removed the pump from the cap we ended up with a stray baring landing in my parts catch and I haven't been able
    to determine where it belongs either. If anyone has an exploded parts diagram for this unit and any information or advice you can lend it would be greatly appreciated!
    Mar 2010
    Hamburg, NY, USA
    2,990
    Default Re: 1986 Tohatsu M70A2 power tilt/trim PLEASE HELP
    Although quite obsolete, a few parts are available... but pretty much no bits for the PTT. The A2 had an additional ring on each piston, but was otherwise identical. I have a reprint Factory service manual available. Your best bet would be to get a used one (45A2, 50C, 60A, or 70A2) that has a bad power head or bad LU, and salvage the PTT parts from it. At issue is that a suncontractor made the PTT units, and they are basically NLA. The parts catalog for the 70A/A2 does not list separate parts for the PTT unit, but some of the newer units are similar. This the diagram from a 70C:
    Paul
    Certified Tohatsu TLDI Technician
    Hamburg, NY USA
    Quote Originally Posted by pvanv View Post
    Hey Paul!
    Thanks so much for the info you shared. I figured that is what I was going to find out simply from how much looking I have done with little to no success at finding anything but vague used parts and a very little specific info! How can I get my hands on a factory manual reprint like you speak of? That would be handy just for general reference!
    Mar 2010
    Hamburg, NY, USA
    2,990
    Quote Originally Posted by Capn Jonesy View Post
    Hey Paul!
    Drop me PM or email p.van.v at verizon dot net
    Paul
    Hamburg, NY USA
  1. Power Trim and Tilt - Oil & Water Seal - Tohatsu m40d2
    By Stevefire in forum Nissan Tohatsu Outboard Forum
    Last Post: 03-25-2019, 07:43 AM
  2. Tilt & Trim motor n pump removal on 1986 mercury 90hp tower of power
    By albeckjr in forum Mercury Mariner Outboard Forum
    Last Post: 10-10-2016, 04:44 PM
  3. 1986 115 HP Mercury Power Trim/ Tilt
    By thebubba in forum Mercury Mariner Outboard Forum
    Last Post: 10-08-2013, 10:49 AM
  4. Replies: 12
    Last Post: 07-01-2011, 04:00 PM
  5. Tohatsu M70A2
    By hdultra in forum Nissan Tohatsu Outboard Forum
    Last Post: 05-02-2011, 11:29 AM
