91 DP 570 FW cooled. leaking antifreeze into bell housing assume its rear freeze plugs or worse cracked block..will only leak under load...no coolant in oil. wont know til haul out and engine pulled. Other problem is port side head notice antifreeze coming from 2 bottom head bolts above engine mount. Used dye test with uv light to verify this. Once again only under load. I had my heads redone by machine shop this summer because a intake valve on Cyl #1 failed. Heads were not warped prior to this and machine shop they were flat not warped. Boat runs and sounds great just pissing coolant from bellhousing and these 2 head bolts not gasket mating area. Could let cool down add more coolant and make short run again before losing to much coolant..nothing in oil, never overheated it, no smell of coolant from exhaust or sheen in water?? Marine mechanic put heads on used proper torque specs and pattern..new gaskets..Any ideas? Advice?
