leiniemann
I have a 78, crusader 270 that I had a loss of power on and returned on one motor. After return I fired up the motor with issue and it would run and idle fine most of the time but did stumble at times and needed to give a bit of throttle then would inlet fine for a bit and stumble again, it also had a noticeable ticking sound. Check oil and it was milky. So I pulled plugs to check compression.Plug from #5 had water on it. It was raining lightly at the time so I could have gotten the water dripping off the manifold but I don’t think so. #’s 7 and 8 were fouled as well, but we’re fine at last plug change this past spring. I expected to have low compression on #5 but it was fine. All were 120-126, except for #8 which was 95. On a recheck of 8 it was 80 ish. and on another recheck 70. Checked #8 with a bit of oil in cylinder and it was 85.
#8 plug also had a fairly large piece of metallic contaminant In it and #5 had a small piece contaminant but could not confirm if it was metallic or not.
I would say that 8 being down is blown head gasket. But what would cause the water on the 5 plug but the compression still good?
Thanks for any input.
