how to adjust bf50 5hp idle somebody help
Hi,
Yes, for the most part, the throttle stop screw is used to set engine idle speed. That is IF the idle MIXTURE screw is properly set.
Since the carb is new, the mixture screw is presumably preset at the proper adjustment at the factory and there should be no reason you would need to adjust it as it is protected from tampering or accidentally being moved by a "cap" that is also installed at manufacture.
Hope this helps you.
You're welcome Bigbigb!
I hope your new carb makes your Honda purr like a....well...a HONDA! ;>)
