Bill Paterson
Hi there from Scotland,
I have acquired and been working on renovating a boat, trailer and an 85hp Force engine and I am a little stuck on two fronts.
1. I have power to the tilt motor but it is refusing to go back down when i reverse the switch and the only way I have managed to achieve this is by releasing the hydrolic fluid. The engine has been lying dormant for some time (unknown) and needed work to free off the lifting pivot and the steering mechanism but this has been successfully achieved. I note, however, that there is a stainless steel striking plate behind the prop shaft which would appear to require to depress a stainless steel plunger when in the down position but this plunger remains depressed when the motor is raised and it appears to be stuck in the closed position. Can anyone advise me how to rectify this please ??
2. I have replaced the ignition switch with a new and similar model which has three positions (off, ignition on and start with a push choke) but i am not confident that i have the correct wiring to the connections. The original switch had six terminals labelled I, M, S, C, B, & M and the new switch also has six terminals labelled I, S, AM, B, M & C. Can anyone please clarify the correct colour of wires to each terminal.
My assumption is as follows; small red to I (ignition), white + white to M (Magneto), large red to B (battery), green to C (choke), yellow to S (start), blue + white to M (magneto), If anyone can clarify the correct connections then I would be most appreciative.
Best regards
Bill Paterson
Best regards
Bill Paterson
