No spark
SCOTTMAN
Hi all, I'm new to boats. I have an 83' omc 2.5L with no spark at plugs. Motor cranks has gas. Has 12v at the following, slave solenoid, starter, ignition coil and at terminal for points, also gap is set to spec. Have lots of battery too. Please help.thanks
any spark from the coil? Best to use an "inline spark tester"....
Used inline spark tester to confirm no spark. No light on tool for all plugs. Trying to source parts( rotor and points. , they seem limited unless you got a lot of 💰😄. Tested condenser, according to the web it's good. Any other ideas? Thanks for your help!
I asked if you had spark out of the coil to get an idea if the issue is on the primary side or the secondary side....if the coil fires, then the issue is it's wire, the rotor, the cap, or the plug wires....
