brian_mcwhirter
Hello,
Last time out, I had an overheat issue at low speed. After replacing the impeller didn't solve the problem, I found that the outdrive hose was kinked. Realizing that the top end of the hose can't be removed without taking the drive, and bellows off again, I quickly lost the stomach for the work.
Has anyone had any luck installing an anti-kink spring into the water hose?
Thanks.
Brian
Thanks.
Brian
