Unknown propeller type
bblagonic
Hi,
My Johnson 60HP from 1984 (J60ELCRE) ser.no. 6101255 has a propeller with code JAA313.
The hub is damaged and the prope is in bad condiditon in general so I have to replace it.
Checking the adequate prop by the part list of subject motor type didn't make any results as it seems that lower unit is different from the original one..The subject lower unit has bigger shaft and housing, too.
The actual prop diameter is 12 3/4 ".
The housing of.the prop is abt. 4".
Could someone help me in detecting the propeller which would fit?
It seems that the code JAA313 is a rare or old one.
Thanks,
Bojan
Post a pic of the prop. if your not finding marking other than those you wrote then take the nut off and post a clear large pic of the hub of the prop by the nut end and we can try and finds it for you........ if its an omc prop pretty easy to know the pitch.. but often if its stainless the marking were extremely fine. here is an example took me 1 hours to clean up enough to see the numbers
... an average starting point for that motor is 13 x17 or 13x 19.. if boat is very heavy then might need to drop down to a 15 pitch...
