moresparks
Hi Quick question if I may.
I believe I am getting wear in the Reverse Latch Mechanism as it can occasionally kick up in reverse, (normally when hard reverse thrust is urgently required)!
As the Bellows etc replacement is due at the end of the season I usually remove the whole drive and take them home for the winter to completely clean, test and paint etc.
So.. I am thinking it’s a good idea to overhaul the reverse latch mechanism, replacing parts etc as necessary.
The question is .. do you have to dismantle the intermediate housing?
The workshop manual shows the intermediate housing having been dismantled.
However I normally keep the drive in one piece just removing cylinder anchorage etc to avoid potential problems, (shimming O, rings etc).
Can you remove the bearing sleeve, guide washer etc without dismantling the intermediate housing from the main "Drive"?
Secondly ... there is mention of special tools / mandrels etc to push out and install bushings etc. ... are these essential?
Thank you in advance.
