Results 1 to 6 of 6
    Default Need Advice on 1991 Johnson 90HP
    My father recently gave me a 1990 Cajun with a 1991 Johnson 90Hp V4 on the back. I need some advice on repair or cutting my losses. I'm a fairly advanced shade tree mechanic so large\complex repair I can most things but I'm also not wanting to dump a ton of time\money.
    Some BackGround.
    1. Boat had been sitting for 2+ years.
    2. My father said the boat has always been hard to start & idol since he has had it for around 6 years.
    3. Once it was running said it always ran great once warmed up.
    Current
    1. It hates to idol and will really only crank with extra throttle applied
    2. Took it on the lake and after bogging\turning very low RPMS around the lake for 30 minutes it would slowing ramp up and run really good and fast. If I slowed down it would take another 2-3 minutes to get up to a decent speed again.
    4. Took it home and changed spark plugs and had nice solid looking spark on each wire.
    5. Drained all the gas and sprayed 2 cycle carb cleaner in the carbs
    6. Took it back on the lake and it would never plain back out and gain speed.
    7. Ran a compression test today and everything is between 60-72 pounds :-(.
    Just needing options if I should cut my losses or maybe try new head gaskets and carb rebuild kit. I got about 1k invested at this point between the batteries\title\and floor repair.
    Alton
    Sep 2010
    20,211
    Default Re: Need Advice on 1991 Johnson 90HP
    No such thing as one of those in good condition being hard to start.-----It should show around 110 / 120 PSI-------So you have a bad gauge -----Poor testing technique ( battery / starter motor ) .----Or a motor that needs work.-----Might as well pull the cylinder head off and looky see.---Cylinder head is warped as they all are on 30 year old motors.-----Head gaskets are cheap !!
    Updated with pics with heads opened up. I have very little experience with 2 cycle but I'm assuming this is not normal... :-( Click image for larger version.
ID:	24522Click image for larger version.
ID:	24523Click image for larger version.
ID:	24524Click image for larger version.
    Sep 2010
    20,211
    There you have it.-----Typical broken piston rings.----Every one of these V-4 crossflow motors will suffer the same fate !!----Seen it countless times myself !!!----These are an easy fix for me.-----If you have to pay a marina you will be shocked at the cost for 4 new pistons to be installed.-----Can be done by a novice with patience and some simple tools !
    Quote Originally Posted by racerone View Post
    That is what I figured..Maybe if I was younger or had more free time. Off to Criaglist\Facebook Marketplace.
  6. #6
    Nov 2011
    tennessee
    4,648
    Dang aluminum termites......
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  1. Johnson 90hp 1991, remote switch raise and lower giving trouble
    By donandsylvia in forum Johnson Evinrude Outboard Forum
    Last Post: 06-19-2018, 08:41 PM
  2. 1991 Johnson 90hp Overheat Alarm
    By JNT in forum Johnson Evinrude Outboard Forum
    Last Post: 04-24-2017, 06:41 PM
  3. 1991 DT55 Oil Injection Advice Needed...
    By fish2day in forum Suzuki Outboard Forum
    Last Post: 03-24-2011, 01:31 AM
  4. Buying advice 1972 4HP or 1991 8HP
    By kevinj in forum Johnson Evinrude Outboard Archive
    Last Post: 03-31-2009, 11:27 AM
  5. 1991 90HP Johnson Alarmsshutting down
    By hardavmotcyc66 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-25-2008, 04:54 PM
