Results 1 to 15 of 15
  1. #1
    Join Date
    Apr 2009
    Location
    orange beach, al, usa
    Posts
    50
    Default Ignition switch Wiring Orientation
    I have a 97 200hp Evinrude E200TXEUA.
    Recently the forum helped me with a kill switch problem. I ordered a new one and installed. I replaced the wires one at a time. I feel I done that correctly.
    The engine cranks and runs well. The problem is, the kill switch still does not kill the engine when the clip is removed (just like it did before). It will start with the clip removed (just like it did before).
    My question is: I am the 3rd owner. If a previous owner had replaced the switch and installed the wires incorrectly-possibly switching two wires or more, would this account for my problem?
    Is a wiring to switch diagram available to check for the correct wires on the correct posts on my ignition switch?
    Thanks!
  2. #2
    Default Re: Ignition switch Wiring Orientation
    Does you lanyard attach to a button or the key swith?
  3. #3
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    4,650
    Which part number did you use?
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  4. #4
    Join Date
    Apr 2009
    Location
    Posts
    50
    The clip hooks to the key switch. If I remember right the switch part number was 5005801.
  5. #5
    Quote Originally Posted by pops86 View Post
    The lanyard that attaches to the key switch simply turns the key off when pulled. If your new switch does not do that then its defective and should be returned. I assume it was installed correctly.
  6. #6
    Join Date
    Apr 2009
    Location
    Posts
    50
    I noticed under "similar threads" Ksan Please help with ignition switch, appears to give me the info I need to check if the wires 6 wires on the backside go to the correct pins.
  7. #7
    There are no wires involved in your safty lanyard.
    Ite a mechanical thing.
  8. #8
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    1,108
    Quote Originally Posted by Rwbutler View Post
    Are you sure there are no wires? I thought the kill switch was wired to the power packs (or is it coils?) and ground with a normally open circuit. When the lanyard is removed it completes a short to ground and kills all spark.
  9. #9
    I have a question: Haven't used the lanyard yet but figure it's a good idea for when i'm alone. From this thread I figured out how it works but I see that it also depresses the ignition switch into the start position when the lanyard is installed. Does that start assist only engage when the motor isn't running or am I missing something? Thanks for your help.
  10. #10
    Quote Originally Posted by kevinj View Post
    Your correct for an older kill switch. We are talking about key switch 5005801.
  11. #11
    Quote Originally Posted by baddog1016 View Post
    it does depress the switch a bit,but it will depress in any position.what is "start assist"?
  12. #12
    Not sure what the real term for it is but on the binnacle it says "Push to Start......." and there's a little more. Engine (2000 225 Ficht) starts better cold when this is pushed in. When warm it doesn't matter. I have two lanyards and they both push it in all the way but don't seem to make a difference on how it idles. Haven't tried them at speed.
    And here's an observation for Pops86. I couldn't figure out the lanyard until I read posts here because I was trying to use it upside down as that's how the lanyards went on a small Tohatsu and Mercury that I had.
  13. #13
    All the OMC or BRP binnacles say push to choke.
  14. #14
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    4,650
    We just went thru at...
    http://www.marineengine.com/boat-for...killing-engine
    Pushing the key in on a Ficht does nothing as all controlled by puter
  15. #15
    Quote Originally Posted by faztbullet View Post
    Thanks!
Similar Threads
  1. Please help with Ignition switch wiring.
    By Ksan in forum Johnson Evinrude Outboard Forum
    Last Post: 04-06-2011, 05:23 PM
  2. J/E Ignition switch wiring???
    By carolinaflare in forum Johnson Evinrude Outboard Forum
    Last Post: 08-11-2010, 09:12 PM
  3. Ignition switch wiring help
    By trxy4 in forum Yamaha Outboard Archive
    Last Post: 09-03-2008, 03:06 PM
  4. Ignition switch wiring help
    By 96chevs10 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-22-2008, 10:22 PM
  5. Ignition switch wiring
    By James King in forum Outboard motors archive 2000-2004
    Last Post: 06-27-2002, 01:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
