Click for Volvo Penta parts and manuals!
Results 1 to 7 of 7
  1. #1
    Default 290sp bell housing zerc fitting
    I have a 290 that has the red bell housing with a fitting ontop of it. Does that fitting need to be greased and if so how often?
    Robert
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,198
    Default Re: 290sp bell housing zerc fitting
    The grease fitting at the 12 o’clock position on your flywheel cover is for the PDS bearings.
    I would recommend greasing them at each engine oil change.
    Apply the grease while the engine is operating at idle speed.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
  3. #3
    Thanks. What type of grease is best and how much should I add? Wouldn’t want to blow out any seals or anything or is that not really possible?
    Robert
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,198
    Stay with the same grease. Mixing greases of different chemistry can cause problems.
    If the AFT seal was installed correctly, you will not blow it out.
    Portland, Oregon
  5. #5
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,198
    Continued:
    As for grease chemistry.
    Certain greases are not compatible with one another. When mixed, they can become liquid like, and will loose their viscosity.
    The AFT PDS seal.
    This seal installs in the non-conventional direction.... I.E., with the lip and tension spring visible from AFT.
    Excessive grease will pass around/through the lip and will simply puke out.
    (this is not a water seal.... it's there to hold grease against the open bearing, but not under pressure. excessive amounts will pass through it)
    If the seal was installed incorrectly, you can drill a small hole in the seal body.
    The FWD PDS seal!
    It is imperative that the FWD PDS seal be either glued or staked in place.
    If this seal was to be pushed out of position (by excessive grease), no future grease will make it through the AFT bearing.
    Portland, Oregon
  6. #6
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    3,470
    RE:...
    So.... given that the O/P didn't even know what to do with that fitting, what does one do greasing wise if one has no idea what kind of grease is in there now ????
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
  7. #7
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    12,198
    Good question, Bob!
    I guess you’d pull that fitting out and reach in and take a sample.
    Portland, Oregon
Similar Threads
  1. torque for bolts in pds housing to bell housing
    By tmcboat in forum Volvo Penta Gas Engine Forum
    Last Post: 01-04-2016, 10:02 AM
  2. water in bell housing
    By capterich in forum Volvo Penta Diesel
    Last Post: 10-04-2013, 09:23 PM
  3. Trouble seperating drive shaft housing from bell housing
    By starsh1p in forum Mercruiser Sterndrive Archive
    Last Post: 11-02-2008, 02:04 PM
  4. BELL HOUSING
    By txny13 in forum Volvo Penta Gas Archive
    Last Post: 02-04-2008, 10:42 PM
  5. Bell housing issue
    By winger in forum Mercruiser Sterndrive Archive
    Last Post: 09-11-2007, 10:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
