Results 1 to 6 of 6
  1. #1
    Default 1990 evinrude 120
    How can you tell if a motor has the quick start feature that advances the timing to help start a cold engine ???
    How does it work / activate advance ??
  2. #2
    Default Re: 1990 evinrude 120
    Yes your 90-120 has quickstart.
    Each time the motor is cranked the power pack electronically advances timing till the motor reaches temp or aspecifided time.
    Thats a short version.
  3. #3
    OK , Thanks tons
    Do you know how to disable it and still get spark without advancing the quickstart feature as I am going to do the WOT advance timing the Joe Reeves method in the shop and he says that you MUST , first disable the quickstart advance feature
  4. #4
    Join Date
    Apr 2010
    Posts
    4,900
    Ground out the white/black wire going to the port temp sender in the head.
  5. #5
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    4,650
    Short the wht/blk to engine ground, this will disable QS. This makes pack stop sending voltage to timerbase which is what is advancing timing in QS
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  6. #6
    You guys are awsome
    Thanks so much
    will getter done !!!!!
    Thanks again !!!!!(:
Similar Threads
  1. 1990 xp 100 Evinrude
    By Rhigley in forum Johnson Evinrude Outboard Forum
    Last Post: 12-28-2017, 03:59 PM
  2. 1990 Evinrude 9.9hp - Won't rev up
    By DeanHensler in forum Johnson Evinrude Outboard Forum
    Last Post: 02-15-2013, 11:23 AM
  3. 1990 Evinrude 120 V4
    By teh3515 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-25-2010, 07:27 PM
  4. 1990 evinrude 200
    By romex in forum Johnson Evinrude Outboard Archive
    Last Post: 01-14-2008, 10:06 AM
  5. 1990 Evinrude 200 XP
    By david_l in forum Johnson Evinrude Outboard Archive
    Last Post: 02-22-2007, 02:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
