Results 1 to 10 of 10
    Default 1999 Mercruiser 5.0 Tuliped valves
    That’s the diagnosis I got, cylinder 2 and 6.
    Shop is recommending a new motor. Machine shop says that the tuliped valves are caused by the valves being sucked up and shouldn’t have caused any lower damage. He says that head work would fix that.
    What do y’all think?
    Jun 2008
    Island Heights, NJ,
    3,473
    Default Re: 1999 Mercruiser 5.0 Tuliped valves
    Yes head work will "fix" the symptom of the problem but not the problem... are the damaged valves intake or exhaust??? NEED to find out WHY this happened in the first place if you are going to rebuild this one... any number of causes including wrong octane gas, over propped, too aggressive timing...etc IT GOT TOOO HOT in the cylinder.!!!
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    Quote Originally Posted by sandkicker View Post
    It's on the exhaust side. They said that the motor was "way out of time".
    Mar 2009
    Portland, Oregon,
    12,202
    Quote Originally Posted by Firescooby View Post
    Shop is recommending a new Engine.
    It would be interesting to hear that machinist's explanation.
    The term "tuliped valve" refers to the valve face in that is has become distorted (cup shaped) due to excessive heat.
    As the face becomes more cup shaped, the effective length of the valve stem becomes longer.
    As the valve stem becomes longer, it now allows the properly adjusted rocker arm to prevent the valve face from seating.
    The problem quickly perpetuates itself.
    I agree with Bob..... you need to FIRST learn what caused the damage.
    Yes!
    It's on the exhaust side. They said that the Engine was "way out of time".
    I'm not sure how they determined that without first operating the engine and checking the TA........... but it is very likely the case.
    Excessive ignition advance can cause ignition induced detonation.... of which can be very destructive.
    Portland, Oregon
    Sep 2010
    Jersey Shore
    5,999
    Unless your engine was used in fresh water, Don't waste your time repairing a 21 year old engine block, there is not much left to the water jacket after that many years. The 5.0 is a crappy boat engine to begin with... Upgrade to a 5.7 if you are going to change the long block.
    Now why did this happen, #1 is a lean condition caused by an intake leak or dirty carb/clogged fuel injector if fuel injected. #2 Boat over loaded creating excessive EGT's and heated up the valve, #3 Bad ignition timing, caused by incorrect base timing or a bad distributor pick up. #4 bad fuel.
    FYI, overloading the boat=over loading the engine... Meaning the engine throttle is pushed up and the engine is lugging not getting into the correct RPM range for the amount of throttle applied. This happening once will heat up a valve and slightly stretch it causing a slight loss of power, not enough to be noticed by the average boat owner. Once this happens the cylinder will run lean and finish off the valve.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  6. #6
    Thanks for the information.
    The boat is a freshwater only boat.
    The boat was running when taken to the shop, just very poorly. They checked timing and said it was “way out”. Compression on all 8 cylinders was 150, 2 and 6 failed the leak down leading to the tuliped valve diagnosis.
  7. #7
    Mar 2009
    Portland, Oregon,
    12,202
    Were they able to give you an exact number as in how much too advanced it was?
    Portland, Oregon
  8. #8
    No they didn't
  9. #9
    May 2010
    DC Burbs/Maryland Eastern Shore
    1,901
    Are you in love with this vessel? If you can't imagine life without it, then I would pop for the repower. If the answer is no, then take the ten or twelve thousand that the repower will cost and put it towards your next seafaring love boat. Sometimes you gotta think with your head and not your heart.
    Maybe you can sell this to someone who wants a project,
    Practicing the ancient art of ren-ching
  10. #10
    Quote Originally Posted by o2batsea View Post
    I only bought the boat in late May, and it's been in shop since first week in June...haven't had it long enough to know. Can't hardly remember what it looks like.
  1. Ajusting valves on my 2.5 GM Mercruiser
    By rivins in forum Mercruiser Sterndrive Forum
    Last Post: 08-16-2011, 01:45 PM
  2. 1986 Johnson 150 Check Valves / Recirculation valves Diagram
    By wtp in forum Johnson Evinrude Outboard Forum
    Last Post: 08-14-2011, 07:22 PM
  3. Water Shutter Valves 2008 Mercruiser 496 Mag w Bravo III
    By jtbehrens in forum Mercruiser Sterndrive Archive
    Last Post: 02-18-2009, 09:49 AM
  4. Mercruiser 50 L 2003 Tuliped Valves and more
    By jacob30 in forum Mercruiser Sterndrive Archive
    Last Post: 12-08-2006, 10:46 AM
  5. 57 mercruiser wtuliped valves on intake
    By joe_p in forum Mercruiser Sterndrive Archive
    Last Post: 10-15-2006, 11:36 PM
