Mickeyfinn
Hi all, I noticed the grommet is wore so much that a lot of water is squirting out. The exhaust housing has been removed and want to install correctly before I replace with a new one. Can I squeeze in from the bottom of the rod or must I remove the upper rod from the powerhead area and insert grommet first? I rather not do the latter unless it is the only way.
