MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
  1. #1
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    16,927
    Default Crankcase sealer
    Opinions please: What are you guys using to seal the crankcase joint? My usual stuff is no longer available.
    Thanks,
    Jeff
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    5,263
    Default Re: Crankcase sealer
    Yamabond, or Indian Head
  3. #3
    Join Date
    Sep 2010
    Posts
    20,298
    Loctite 518.----You have to use a sealer with low " filler " content.----You want most ( 98.5 % ) to squeeze out.----Just so you end up with a film 0.0005" thick for proper bearing and reed block " clamping " on assembly.------I have seen a film of sealer up to 0.008" thick which meant the bearings and reed blocks were loose and motors went " boom " in short order.
  4. #4
    Join Date
    Sep 2003
    Location
    Posts
    16,927
    Thank you!
    Jeff
  5. #5
    Join Date
    May 2020
    Location
    Stokesdale NC
    Posts
    314
    A little research on Permatex website says that Loctite and Permatex are cousins or closer. If the row from their product interchange will copy properly this is what I found.
    Which fortunately I already have.
Similar Threads
  1. Replies: 4
    Last Post: 03-04-2011, 11:13 PM
  2. Stainless Head Gasket Sealer or No Sealer
    By mike77cj in forum Mercruiser Sterndrive Archive
    Last Post: 06-13-2009, 01:12 PM
  3. 60 hp crankcase cover sealer application
    By Greg hare in forum Mercury Mariner Outboard Archive
    Last Post: 06-25-2008, 12:41 AM
  4. Gasket sealer or Not
    By luvthewater2 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-17-2006, 07:43 PM
  5. Sealer
    By Joe Reeves in forum Johnson Evinrude Outboard Archive
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
