Here is the run down. 2002 Mercury 50hp 2stroke 3 cylinder model #1050412ZN. The engine will start relativley fine and will idle okay on muffs and on the water. On the water, while in gear under throttle the motor runs fairly smooth and sounds good, but it feels restriced and lacks power. This engine has an electric choke on the ignition. With the engine under WOT it runs feeling weak and restricted unless I activate the choke. If I constantly activate the choke, push the key in every 1.5-2seconds, the rpms ramp up, power is restored and runs as it should. I'm trying to figure out what the next step in my diagnosing should be.
The following things have been done in less than a month, and were all done before water testing. The same problem still occurs.
Carbs have been cleaned/rebuilt
New fuel tank, tank hose/bulb, new fuel line from tank hose to fuel pump, new fuel filter.
Fuel pump has been cleaned and rebuilt
Spark plugs have been inspected and cleaned.
I'm all out of ideas. Please help!!
