MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
Thread: 1968 900
  1. #1
    Default 1968 900
    So i come across a 68' merc 900....looked pretty well, but been hanging on the boat for a couple of years ( out of the water). Did a compression check on it and was 150PSI or a touch better on all 4 cylinders. did not have enough to try to start it as the wiring was iffy....oh and it had a 2 blade prop.
    What do ya'll think it is worth??
  2. #2
    Join Date
    Sep 2010
    Posts
    20,281
    Default Re: 1968 900
    Was this a 4 cylinder 900 model ???-----Are you 100% sure ?----Serial # or pictures of motor and decals by chance.---I do not see a 4 cylinder 900 model on any list.
  3. #3
    Join Date
    May 2007
    Posts
    9,267
    If the year is correct they didn't make a 90 that year - in 68 there was a 50 (4 cylinder), a 65 (4 cylinder) then the next model in the line-up was a 100 horse (6 cylinder) with "nothing" in between as far as HP went.
    So if it's a 68 you have either a 50 or 65 horse.
    And since it's not "restored" and has been sitting, to get a value I would take the weight of it, multiply it by the current scrap price per pound for aluminum and divide by 2 (to get a discount for your trouble if it can't be repaired).
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  4. #4
    Your right fellas.....fat finger syndrome # keystroke error. It should be 800​ not 900
  5. #5
    Join Date
    Sep 2010
    Posts
    20,281
    Sorry----But you need to understand that in 68 there was no 800 model either.-----Learn to post pictures !!
  6. #6
    ahhh jeeeze 1969 800 not the actual engine just a photo
  7. #7
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    3,193
    Great motors. Expect bad wiring and lower unit contamination. Check lower unit carefully. Compression is dynamite. Might not be scrap. Gotta be careful with wiring.....you might start toasting parts if you don't inspect first.
Similar Threads
  1. 1968 sea ray 24'
    By dimitrimfogal in forum Boat Trailers - Repair, Parts & Advice
    Last Post: 02-26-2011, 09:07 PM
  2. were to buy? 1968 33 hp
    By davidtroutt in forum Johnson Evinrude Outboard Forum
    Last Post: 12-18-2010, 10:45 PM
  3. 1968 9.5hp Sportwin is this right?
    By pennsylvania_newt in forum Johnson Evinrude Outboard Forum
    Last Post: 05-07-2010, 12:39 PM
  4. 1968 ted williams 75
    By billhunthunthunt in forum Ted Williams Outboards
    Last Post: 07-21-2008, 07:47 PM
  5. 1968 classic 50
    By hadaveha in forum Mercury Mariner Outboard Archive
    Last Post: 05-08-2007, 01:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
