This is a fuel flow problem. Nothing else. There are some folks on the forum who know this engine and my problem, so they’ll know what I’m talking about. Before anyone else chimes in about anything other than fuel flow, please this ENTIRE thread: http://www.marineengine.com/boat-forum/showthread.php?438706-Inboard-95-Mercruiser-GM-350-EFI-Magnum-Skier-limited-top-speed
Then you’ll know what I’m talking about too. Thank you.
After doing a tuneup that included plugs, plug wires, cap and rotor, fuel filter and cleaning the flame arrestor, I removed the mechanical fuel pump and plumbed a direct line from the fuel filter to the electric pump. No mechanical pump in line at all. On a test run, she took off like a scalded cat and ran right up to 4400rpm! First time ever since I got the boat 4 years ago. But it only lasted for about 90 seconds. The it bogged and spit and limped back to the dock.
So at least now we know she will run to WOT, though I’m pretty sure I have to get the mechanical pump back online to make it happen permanently.
Before the Vapor Separator Tank (VST) was tossed by the previous owner, the TBI fuel return ran to it, as did a supply line from the mechanical fuel pump. They entered separate chambers in the VST, which then metered the fuel to the electric pump for the TBI.
Now, the fuel return is hooked up to an inlet on the fuel filter, and when I first got the boat, it ran to a brass tee in the tank fuel line before the mechanical pump. Is it possible/probable that, without the VST, these two low-pressure fuel flows are fighting each other, causing the electric pump not to be able to supply enough fuel to reach WOT?
I’m installing a new mechanical pump and hope to lake-test mechanical/electric setup tmrw nite. If it doesn’t get me to WOT again, I have a couple other workarounds to try. Interested to hear from the folks who are up on this story from the beginning. Many thanks for all your help thus far.
