I've have a lingering cooling issue I thought was a simple thermostat issue, but... The symptom is the water temp gauge bounces from 170-100 after the thermostat opens. Some times it drops at 130F, and some times it sticks at ~110F. What I've done:
- Replaced the thermostat w/ a genuine Merc part, including all gaskets; twice in case the first one was bad out of the box.
- Replaced both port & starboard temp sending units on the thermostat housing.
- Replaced the impeller in the sterndrive.
Current Status:
- Today I broke down and purchased a new Water Temp gauge. The old gauge appears to be bad. At the same time, with the new gauge, the engine reaches 160F, then drops to 120F and stays there.
Starting cold, the engine comes up to temp (160F), thermostat opens, temp drops to ~120F. This is in the driveway, connected to ears & garden hose. Using a laser heat gun, the top of the intake manifold (roughly under the carb) is reading ~175-180 while running at ~1,500rpm. The exhaust manifolds are reading 120-140F (starboard side always runs hotter). I have good water flow out of the sterndrive, and I've even open the drain plugs from the block and manifolds (carefully) when it is idling to ensure I have good flow.
I would swear in the 23 years I've owned this boat (original owner, '97) it would warm up to 170F and stay there during normal operating conditions. The only thing I haven't done is replace the actual water pump on the engine.
What am I missing? (4,3L V6, Alpha Gen+)
Andy T.
Tacoma WA
Current Status:
Andy T.
Tacoma WA
