'89 Evinrude 90HP V4 VRO.
Model# E90TLCEM, Serial# QJT650961607
I was out running at full throttle, engine was running fine when suddenly the engine acted like the throttle was pulled back to just above idle (5 MPH). Limped home, called mobile marine repair guy.
Here is what he has tried so far over the last two weeks:
Any thoughts or suggestions appreciated.
- New spark plugs
- Compression check - 120,120,120,119
- Timing base (from known good motor)
- Stator (from known good motor)
- CDI unit (from known good motor)
- Checked for broken carb reeds
- Checked butterfly valves opening fully
- Cleaned carbs
- Hooked up remote fuel tank
- Installed new propeller (old one was damaged)
