New Ford 351 with GT40 heads overheating at idle need help bad
if you picture above you show hex head bolt with out threads on the first 1/2 or so, does that part matter? I assume that the bushings has to be lose enough for the threads to clear.
Thanks for your help, I hope this solves the problem.
I may not be following you, but I'll take a stab.
The portion of the bolt that will penetrate the bushing ONLY, will not have any threads in this area.
This is the "shank" area of the bolt, and will ensure a good fit between itself and the ID of the bushing.
attachment.php
