badcrank 777
Hello Everyone,
I am posting a new thread, because in the last thread all was fixed and I have been enjoying boating up until yesterday.
Was doing fine, perfect idle, engine purring like a kitten running smooth at 4500 RPM all day. Stopped the engine, when I restarted it, idles fine but went to advance the throttle, and it would not get above 2200 RPM. The tach went to zero and was acting very strange, like swinging from zero to 5500 and everything in between. Also even at 2200 the motor was stumbling and shaky.
I am using "clean fuel" no ethanol. There is nothing blocking the fuel lines, nor any air leaks. water cooling is working just fine. The carburetors are clean with all new gaskets plus needle & seats. And like I say it has been running perfect for days, until yesterday. I have not done anything yet, going to look today.
But thought before I start tearing things apart, was hoping to get some guidance as to what might be causing this issue, so I don't go off in a wrong direction.
Thank you
Thank you
