I have a 90's Mercury 9.9 that stopped peeing reliably (would sometimes). I started getting steam out of the weep hole. I pulled the lower unit off to check the impeller and flush it out. Our lake is pretty mucky so I figured some junk got sucked in. Pulled it apart and the impeller is perfect and the key is in place. I flushed it out and I tested the unit in a bucket. When I put it in neutral and spin the driveshaft clockwise with a drill, I get water pumping. Figured I took care of it. I reassembled it to the motor, but still not getting any water out of the weep hole, just steam after it heats up. I had the LU off 3 times trying to figure it out. I tried to make sure I got the tubes lined up right and everything.
Last time with it off, I put a rubber tube onto the copper water tube inside the shaft. When I blow through it, I hear it and feel it coming out of the weep hole but if I plug the weep hole while blowing, I do hear air escaping inside the shaft somewhere else. Is that normal? Could the pump be working but the water escaping into the shaft somewhere before getting to the block?
Any suggestions on next steps for testing or repairing would be greatly appreciated!
THanks all
THanks all
