Old man laker
My 2005 4.3L mpi s.n.0w064797 really has me stumped. So as I said in my first post I’m having an issue where I’m unable to go over 2800 rpm AFTER approximately 10 minutes. New cap,rotor,wires,plugs (again) oil and filter, fuel filter. Water pressure sensor,temperature sensor, have also been replaced. Engine temp runs 170 and never higher. fuel pressure is 42 key on,38 at idle, did wot test and pressure was 41 psi. I believe this is acceptable. IAC replaced and that’s what stopped the beeping. But.... still can’t get over 2800 rpm.
Ordered a 160 thermostat, due in tomorrow. Spoke to the local merc tech still looking at mid August before I can get in for a scan. So any and all ideas are welcome.
Here’s what Happens: run motor to 170 degrees at dock, take out on lake and can run wot (4800) or even say 3100 no problems for around 10 minutes or as I did today just started it up on went straight out 10 minutes later won’t go over 2800. If I keep it just under 2800 and I check all the trim so we’ll just go over 2800 it’ll drop to 2600 and bounce back back-and-forth 2600 to 2800 however if I try to give it more throttle it’ll bounce down to 2200. No alarms so my question is is this going into Guardian mode or am I having an ignition breakdown say a coil or a distributor sensor.
