6 temperature alarms showed up in the history when the computer was plugged into engine. Never showed up as a light on the key switch panel.
We cleaned out fuel bowl and replaced thermostats. Alarm still happening (although greatly reduced when drove shortly without the thermostats in).
Previous owner said he completed the following maintenance May 2020: oil change, oil filter, both high and low pressure fuel filters, spark plugs, fresh bottom paint, lower housing shaft bushing, and complete impeller and housing replacement; Both batteries are new 2017/2019; Bilge pump and float switch were replaced in 2019
Thanks - just want to get out on the water with our girls!
Any mechanics in Westchester, NY area? Any ideas appreciated.
