tthomp1334
Should the fuel line from the fuel pump to carb hold pressure after you turn off the ignition.
Been having with engine bogging down after about 1/3 throttle under a load so I hooked up a pressure tester on the fuel line that goes from the pump to the carbs.
Could only get about two pounds of pressure at idle and hardly any at 1/2 throttle with no load on engine., kill engine and no pressure.
The pump has new gaskets and diaphragm.
Could it be bad check valve in the pump.
Milton
Milton
