MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
    Default 1962 Mercury 110 water pump HELP
    I can not get the water impeller out or to move off the shaft..Is this model different/. The S/N is 1495375..Any Ideas?
    Thank you!
    Sep 2010
    19,802
    Default Re: 1962 Mercury 110 water pump HELP
    Same as all the rest.----But the impeller could be jammed by rust.
    Sep 2003
    New Tripoli, PA, USA!
    16,836
    Take a small sharp chisel and split the brass center part. It will then come right out.
    Note that there are two different impellers for some of those motors.
    Jeff
    Quote Originally Posted by fastjeff View Post
    Jeff
    Thank You Jeff I got off!! Also this one had a round pin on the shaft..I've seen on a few Videos one that have a guide pin// Not this one
  1. 1962 johnson 18 hp fd16a won't spit water
    By J.pettit in forum Johnson Evinrude Outboard Forum
    Last Post: 07-19-2018, 11:12 PM
  2. Fuel pump for 1962 sea king
    By tophertodd in forum Johnson Evinrude Outboard Archive
    Last Post: 06-21-2009, 01:26 PM
  3. MERCURY WATER PUMP
    By gdon23 in forum Mercury Mariner Outboard Archive
    Last Post: 05-29-2009, 04:25 PM
  4. 97 20 hp mercury water pump
    By muskypro in forum Mercury Mariner Outboard Archive
    Last Post: 01-20-2006, 10:30 PM
  5. 1962 evinrude not pumping water
    By john in forum Outboard motors archive 2000-2004
    Last Post: 05-03-2002, 04:31 PM
