95 Mercruiser 350 Magnum Tournament Ski TBI fuel pump replacement
pwskicat
Ser. #0F652552 Installing a new low-pressure pump that runs off the block. Any tips or tricks? Many thanks for your help, PW
any pump mounted to the engine block where a fuel pump goes will not work for a TBI. You need atleast 30-32 PSI for the 2 injectors
Yes. I'm replacing the lift pump tht feeds he high-pressure pump. Fuel pressure spec to the injectors is 30 psi, controlled by a regulator in the throttle body.
