Dmosherbuyno
ok, so this is everything I have done to the motor and I am getting nothing...
It started up in the beginning but ran bad, so I rebuilt and cleaned the carbs, replaced the spark plugs.
When I went to start it up I accidentally hooked up the main positive to the negative terminal and visa versa. It ended up melting the negative terminal.*
I replaced the starter solenoid, ignition coils and rectifier. Im getting power to the starter solenoid, tilt and trim buttons on the motor work fine.*
When I go to crank it clicks once and does nothing, I go to crank it again and no click and nothing happens. The only thing I haven't replaced is the starter which I just ordered today.*
Other than the starter, what else could be the issue? This is killing me....tmenk you for your help.
