Click for Crusader parts and manuals!
Results 1 to 7 of 7
    Feb 2007
    275
    Default Heat Exchanger inlet vs outlet temps
    Hi Guys
    Just curious as to what temp reduction percentage one might see on a healthy heat exchanger inlet vs outlet on the closed side at idle and under load.
    Half systems and Full systems.
    Jon Allen
    Mar 2009
    Portland, Oregon,
    12,115
    Default Re: Heat Exchanger inlet vs outlet temps
    Jon, I just did a quick search regarding a car/truck radiator cooling percentage...... and found that approx 25% to 30% of the engine's heat is transferred into the engine's coolant. I'd think that those figures would be low given that the Marine Engine is always under load.
    As you know...... the Marine Engine heat exchanger performs the same task as does a car/truck radiator, but with much more efficiency due to the liquid media, versus air.
    Portland, Oregon
    Feb 2007
    275
    Hi Rick
    Thanks for the quick reply.
    It’s tough to convince a boat owner to allow for a intrusive heat exchanger inspection during a survey.
    I like to see a 40 degree difference at a fast idle and at cruise spd.
    25 to 30 % makes sense.
    Any thoughts on max elbow temp at cruise spd. ?
    I’m thinking 140-160 f
    Thanks Again
    You have been such a big help to me over the years.
    Jon Allen
    Mar 2009
    Portland, Oregon,
    12,115
    Quote Originally Posted by jon_allen View Post
    that was an automotive example.... the marine cooling system % may be greater.
    Most will suggest that you should be able to put your hands on them.
    Keep in mind that the elbows only see "spent seawater".
    In other words, they are being fed with the seawater that has already removed the heat from the heat exchanger (half system) or from the heat exchanger and exhaust manifolds (full system).
    Thanks Again
    You are very welcome!
    Portland, Oregon
    Sep 2008
    Maryland - USA
    8,360
    I usually worry more about the rise on the raw water side.... 50 deg F rise is a sign of a healthy cooling system on a full FWC Big Block at cruise....60 deg F rise is max I use before its time to start inspecting...some prefer to use a pressure increase to indicate excessive restrictions.
    a 40 deg F delta on the closed side is about the best I've ever seen on a full system....30 deg F is more 'normal' based on my limited data set...and this assumes the raw water side is in good condition.
    As far as the reluctant owner goes, if they don't have a complete log book with detailed maintenance records, they really don't have a basis for objecting....
  6. #6
    Feb 2007
    275
    Hi Mark
    Thanks for getting back to me.
    Its tough to make a call on a heat exchanger’shealth
    as the flow rate of the exhaust can affect the temps.
    I will take your advice as well as Ricardo’s
    Thank you for all of the great advice you have brought to this forum over the years.
    Jon Allen
  7. #7
    Sep 2008
    Maryland - USA
    8,360
    Agreed that it can be a challenge....on the health side, besides the cooling function, I usually suggest a good visual inspection under the end caps and pressure test....its no guarantee but about the best one can do...
  1. Heat exchanger
    By jaynkay in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 07-02-2020, 07:34 AM
  2. When a heat exchanger goes bad
    By matta0413 in forum Crusader Marine Engine Forum
    Last Post: 07-24-2018, 04:44 PM
  3. Inlet cover J & T part #1028 for heat Exchanger
    By harpemark in forum Detroit Diesel
    Last Post: 02-18-2013, 12:46 PM
  4. Heat Exchanger
    By sroberts in forum Crusader Marine Archive
    Last Post: 09-20-2008, 07:29 AM
