This engine had this problem 23 year ago and it's been sitting ever since. I replaced the prop with a new one because the old one obviously had a spun hub. You could see where the bushing had slipped and the center was sticking out.
I took it out yesterday and started it up for the first time. I got the engine good and warm and decided to give it a try because I was able to pull start it easily after warm up. As soon as I opened it up, it popped out of gear. It's a manual shift tiller drive. I know the shift rod was right so I drained it and can see the a rounded edge on the clutch dog. The forward gear has 2 slight rounded edges, but they aren't near as bad as the clutch dog.
$150 for a replacement...Is it possible to just flip the clutch dog and run it backwards? Reverse doesn't require the high rpms forward does....Just curious if that will buy me time and get more wear out of the part.
