RichardInDorset
Refurbing a 140hp V4 VRO that has sat a LONG time.
Finally got the gearcase off to put in a new water pump.
Thought I'd test the water circuit, so I put a hosepipe direct onto the water tube, while the gearcase is off.
No water seen at tell tale. Water is coming out of a hole next to where the water tube enters the engine casing, right up inside the mid section.
Shouldn't there be water at the tell tale?
Does the motor need to be turning or running?
Is there a valve somewhere that might be stuck?
HELP!
HELP!
