bryan harris
1985 yamaha 2strk 70 hp.(oil injection pump) is it worth using? i see where some people block it off, And pre-mix fuel themselves. after purchasing motor and inspecting, noticed linkage from pump to carb, that the plastic joint links, that attach the linkage were cracked and not operating correctly. ordered new ones from you. gonna try them . your opion? thank you sirs>
