Results 1 to 8 of 8
  1. #1
    Default Johnson 40hp elecromatic, runs but won't restart
    Ok A-Team,
    I got the ole girl running, 10+ minutes no issues. Shut her down and the try to restart and it is a no go. Doesn't smell flooded everything seems good, any ideas?
  2. #2
    Join Date
    Sep 2010
    Posts
    19,777
    Default Re: Johnson 40hp elecromatic, runs but won't restart
    Does spark jump a gap of 1/4" ( 8 mm ) or more, yes or no ?---Or just not sure why that test should be done ?
  3. #3
    Join Date
    Nov 2011
    Posts
    2,867
    Typical symptom of bad coils, but that is jumping to conclusions.
  4. #4
    Ok, I'll check them. Thanks!!!
  5. #5
    I'll check the gap and spark.
  6. #6
    Could that be because the coils get to warm, just wondering?
  7. #7
    Join Date
    Sep 2010
    Posts
    19,777
    Just do the testing.
  8. #8
    Join Date
    Nov 2011
    Posts
    2,867
    Old OMC coils are notorious for age-cracking, that's why we automatically assume. Besides, we don't know whether yours are original or replaced last week. And also why racer said check the spark. BTW, old cracked coils can throw a weak spark, but not run. But nevertheless, a spark check is the first place to go.
Similar Threads
  1. Johnson 40hp elecromatic won't fire
    By Danac in forum Identifying Model / Year / Horsepower
    Last Post: 06-19-2020, 04:55 PM
  2. Johnson 40hp elecromatic won't fire
    Last Post: 06-19-2020, 03:52 PM
  3. Johnson 40hp elecromatic ignition switch issues hi everyone
    By Danac in forum Johnson Evinrude Outboard Forum
    Last Post: 06-11-2020, 12:23 PM
  4. 1982 Johnson 115hp Runs and then will not restart until a few hours have passed
    By LDSampson in forum Miscellaneous marine engine topics
    Last Post: 10-16-2019, 03:32 PM
  5. 150 Johnson (2001) Carb - Starts, runs, engine is hot turn off, will not idle on restart
    By Mjreynolds928 in forum Johnson Evinrude Outboard Forum
    Last Post: 10-06-2019, 01:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
