Results 1 to 8 of 8
  1. #1
    Default 1996 Johnson 90HP Model J90TLEDA
    Engine starts and idles great. Give it WOT goes for about 200 feet and bogs down like it is running out of fuel. I have rebuilt the Vro, Put a new powerpack in it, New coils, New plugs and wires, and rebuilt the carbs. Just can't figgure this one out. Any ideas? Thanks.
  2. #2
    Join Date
    Sep 2010
    Posts
    19,757
    Default Re: 1996 Johnson 90HP Model J90TLEDA
    The first step in trouble shooting that motor is a compression test.----Post your numbers.
  3. #3
    Engine runs fine gets right up on plane. Plenty of power. Something is shutting it down or it is running out of fuel.
  4. #4
    Join Date
    Sep 2010
    Posts
    19,757
    Good luck with your motor.----Maybe try a new stator and trigger / sensor / timer base.------You may get lucky.-----Trouble shooting / testing is a lot cheaper than spending $1000 on parts like a blind squirrel.
  5. #5
    ya ok. go check your compression.
  6. #6
    Any other ideas beside the compression tester?
  7. #7
    Quote Originally Posted by ffej3580 View Post
    What is your fuel pump pressure?
  8. #8
    Could it be warped carb bowls, or had they gone to metal by then? The plastic ones will definitely warp. It won't show a gas leak, but it will let air get in when the fuel pump is pulling fuel.
Similar Threads
  1. 1996 Johnson 90hp v4 not starting after sitting for a week
    By Basmn in forum Fuel / Oil Mixture Ratio
    Last Post: 01-14-2020, 03:22 PM
  2. 1996 Johnson 90HP Incorrect oil mix need some help
    By mcd227 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-20-2009, 03:40 PM
  3. 1996 90hp Johnson J90 eledr
    By whelaniii in forum Johnson Evinrude Outboard Archive
    Last Post: 03-19-2009, 09:15 AM
  4. 1996 90HP Ocean Pro model E90SLED how to change from
    By scumbuster in forum Johnson Evinrude Outboard Archive
    Last Post: 04-19-2007, 12:36 AM
  5. Tachometer fault on 1996 90HP Johnson
    By rockcodrick in forum Outboard motors archive 2000-2004
    Last Post: 06-21-2002, 07:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
