[email protected]
So, been keeping this thing alive since granddad bought new. Learned a lot, but still have a lot to learn. Made my first attempt at swapping lower units when i lost a shift solenoid and made a big mistake on the install that resulted in bending one of the water tubes that runs up exhaust housing. I didn't have a feel for it and used the bolts to tighten it up the last 1/2 in. or so. Don't think i can salvage the tube that is there.
So, big question is, can the tube be replaced without removing powerhead and exhaust tube?
As a side note, the lower unit i am putting on his 100% good. I know because it is the original and operated perfectly when the wrist pin finally gave up on #2. This one can be rotated fine in either direction from the input shaft. The prop shaft on the other hand will not allow you to spin manually in reverse. Seems to hit a hard stop.
Lower unit #2 (with one bad solenoid, circuit open) operated fine until stopped shifting. Seems very loose on the gears as you can feel the teeth engage eachother as it is rotated. It spins both ways open with the input shaft as well as the prop shaft. -SO, should the prop shaft spin in reverse? Or could the mode of solenoid failure leave the gears in a position to allow this? Hard to see how since, as i understand it, the solenoids just change oil pressure. As a side note, this unit was running HPF Pro per trusted local dealer recommendation which i now understand to be big no no. Type C is way different.
Would also greatly love any tricks of trade when i go to reinstall this about getting those water tubes to line up and seat. seems like there must be a trick to it.
