Eric the rookie
I recently purchased this old boat. I have some questions for anyone familiar with this engine. First, the old mechanical and newly purchased mechanical don't seem to be pushing fuel despite some barely visible marks on the tang. An Autozone 2 to 3.5 lbs. electric gets hotwired to the battery for it to run which it does. However, when under a load in the water it doesn't go faster, just hesitates then backfires slightly out of the carburetor. I have a rebuild kit for the carb coming, but, in trying to wire up a toggle switch for the pump the wires get hot and have to be immediately disconnected. Obviously I have to properly wire this switch (I've read briefly about oil pressure switch, relay etc.) I'm wondering if that low pressure pump is inadequate to begin with, need 7 lbs? Any help with this boat moving forward would be greatly appreciated!
