engine weight 360
Cape Dory
Need to build engine hoist inside cabin of my Cape dory 28. I have the engine stripped to block,heads and transmission need approximate weight for building hoist over engine using chain fall
makomark is correct, a little extra capacity is wise.
These weights are for a 318 which is the same block as the 360 with a different bore.
Engine weight
Bare engine: about 560 lbs. With manifolds: About 650 lbs. With bellhousing and starter: About 750.
