Charging system problem
Ramhad3
I have a 115 HP 2 stroke outboard Merc.
Problem: Battery not charging when running.
What I have done:
Replaced the rectifier
Can I check the status of the stator when it is still installed?
I pulled the connection to the stator and checked the connections with these results.
Blue: 7.47
Red: 116.3
Yellow: 1.0
I think it could be the red coils that seems high, blue seems low, yellow looks ok. But is that because I did not remove it from the flywheel?
Ok thank you, So the yellows seems to be good then, Any ideas on why its not charging, rectifier has been replaced already
