carphunter
During testing a couple of weeks ago, engine dropped power while running... felt like less than 1/2 throttle worth of power. couldn't plane, etc. engine didn't die. no warning whistles... water pump pissing fine.
as i nursed it back to landing, i found that if i dumped fuel in with the key primer and released the primer, it would run the rpms back up, but as that fuel burned, i came back down to the low rpm.
mechanic thought it might have a rev limiter i hit while running and that pushed it to limp (and if i had turned off and on, it might have resumed normal operation).
I'm just trying to find out... do these engines have a "limp mode?" and if so, what's the reset?
