Results 1 to 6 of 6
    Default 91 omc cobra 4.3 setting timeing after distributer gear replacement
    So I have a 91 omc cobra 4.3 that has a bad gear on distributer I'm looking to replace it and was wondering how to set timeing wo timeing light after I replace it.
    Mar 2009
    Portland, Oregon,
    11,996
    Default Re: 91 omc cobra 4.3 setting timeing after distributer gear replacement
    There’s no way to properly re-install your distributor (with a new driven gear on it), without the use of a timing light!
    Portland, Oregon
    Apr 2009
    Long Island, NY,
    184
    Auto shop 101....if it’s a points distributor you also need to learn to setvpoints with a dwell meter.
    Jun 2006
    Spotswood, NJ, USA
    5,131
    Yes ,you can install a dist and not worry about the timing and get the motor close and running but if your too advanced or too retarded you will damage the motor .
    So when we removed the distributor we marked it and have not turned the motor over at all. Would that make a difference?
  6. #6
    Mar 2009
    Portland, Oregon,
    11,996
    Quote Originally Posted by Cchiasson40 View Post
    So when we removed the distributor we marked it and have not turned the Engine over at all. Would that make a difference?
    Yes!
    The spring pin bore in the new gear will not be in the same location, therefor the gear teeth will not be indexed in the same way.
    Portland, Oregon
  1. Setting gear handle of 200, 20 hp 1980
    By Eric Hoare in forum Mercury Mariner Outboard Forum
    Last Post: 05-17-2016, 01:01 PM
  2. Distributer setting for a 4.3 V6 GM engine
    By hordos in forum Volvo Penta Gas Engine Forum
    Last Post: 07-06-2012, 10:11 PM
  3. Water sep replacement 57l OMC Cobra
    By boatin_bob in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-22-2008, 02:36 PM
  4. OMC Cobra 23 Ford Distributer Shaft
    By brwilson in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-22-2007, 11:53 PM
  5. 84b 150hp Black Max Misses on idle amp low gear setting
    By hsp in forum Mercury Mariner Outboard Archive
    Last Post: 06-06-2007, 09:26 AM
